Starting issue
Craig Harrison
Nowra
2007 VE SV6 Holden Commodore ute
Good Afternoon
I currently own 2007 VE SV6 Holden Commodore Ute with 270,000 Km. The issue I am currently experencing is starting problem on warm to hot days where it can take up to 3 times before the vehicle starts and when it does start it runs rough for few seconds and then comes good and runs fine I am able to hear the fuel pump when you first turn the key I am not sure given the amount of kms on the vehicle would this be sign the fuel pump is about to give in and I should look at replacing before I get stranded or would it be some other problem such as dirty sensor.
lazyc
Eagle Farm
VE SSV 6.0 M6
Purge solenoid.
Pull it out and try to blow/suck on it.
It should seal with no power.
If faulty, replace $60-70 from Holden
It has no fault code and can show up on hot days and after a refill at the petrol station
Craig Harrison
Nowra
Purge solenoid.
Thank you very much I will give that ago.
Kingcarl
VE Sv6 series II MY 12.5
Purge solenoid.
Yes you can get fault codes thrown up relating to this issue.
Grande316
2007 VE Omega Ute
Purge solenoid.
Mine has been rough starting after filling up. Will check it out.
