Starting Problem
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Jecs, Mar 3, 2012.
  1. Jecs
    '97 Caprice 355ci & VZ SS Ute
    ive recently put a new battery in my car. and everytime ive changed the battery in my car its gone into a lockin mode. u turn the key, it primes the system, try to crank it over and it'll ignite but only with the fuel in the prime system. its like it switchs off the fuel pump off from constanly running.
    last time i fixed it i did something like: locked the car, unlocked it, opened the doors, pop'd the bonnet, then closed everything and it started.
    but i cant figure out how to do it again, anyone know what the procedure is?
  2. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    have you checked fuses and relays?
  3. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    Sounds like you have a problem with your Immobiliser engaging the fuel system. You could try running some direct power to the fuel pump to see if that helps.
