Starting problems
COMMYBRO
SA
VS Berlina
Hi i have recently put a VX Trans into my VS commodore when i went to start it all i get is a tick noise.. i dont think it has anything to do with the trans being swapped. i have put a new battery in the car but still all it does it tick and if you do it long enough the starter heats up and smokes. could this be an electrical problem, immobiliser or something along those lines?
VR_Acclaim
Banned
Vr acclaim
I would say wiring mate, or the starters rooted mate
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Sounds like the pinion on the starter motor has gotten jammed against the ring gear on the driveplate when you've installed the transmission or the ring gear/starter is the wrong one - this will prevent the starter from operating. If it's smoking it will be cactus unless you are very very lucky.
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
Re installing the starter motor might solve the problem?
