Starting problems
N
noodle2100
Guest
VT S2 intermittent starting problem, all lights on dash show but starter doesn't engage. lock and unlock car, put into N and then back to P, try again might or might not start. try again and with luck it will go. any hints from anyone with similar problems as to what the answer is!!
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Could be the neutral start switch which stops the car from starting in gear. I have the same problem sometimes and like you I take it out of park and push it back into park a little harder and it usually starts. Try starting it in neutral, it often works for me.
TigerVX
2000 VX Commodore
Most likely the selector linkage like accentstencil said. Nothing major, you'll just need to get it readjusted. You can do it yourself if you've got ramps or a jack and stands.
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
Hopefully one less problem for you accentstencil with your new box.
Have you installed it yet?:p
accentstencil
68
Eschol Park, Sydney
No I haven't installed it yet but hopefully I will get it done soon. I'm not in a real hurry as the old one is not too bad, I just don't expect it to last much longer havind done 263.000 kms. A lot of those kms were done towing a trailer with heavy loads, sometimes well over a ton. I just thought I would snap up the other one for $152 and have it on hand rather than wait till I needed one and have to pay a lot more.
beeks
Banned
N.S.W
XR6 5sp MKII + DR 600S
Could be your starter motor.
doug05
CV8Z Monaro & VF2 SSV Redline
Mine did a similar thing a while ago, all lights engaged and when i went to start it, nothing....
Found out eventually it was the starter relay. A nice cheap fix!
fudlop
37
vt commy
my mate car was doing exactly the same thing, turned out the key was stuffed.
Gothevu
Off the chain
Townsville QLD
VU S2 Ute - 5 sp manual
Could even be your battery terminals, just get em a clean and see if thats a problem
