stateman power hose replacement
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by umair, Feb 8, 2012.
  1. umair
    umair New Member
    saudi arabia
    Sold my car :(
    I have wh statesman and the short hose of the power steering reserviour leaks very slowly. I have to top it up every two weeks. I live in saudi arabia and they do not have any hose in stock. I tried a heater hose but it got bended where it curves. What kind of hose can I use. Heater hose will not work. I need something flexible.
  2. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    Try tightening the hose clamps?
  3. SavVYute
    SavVYute Active Member
    VY S V6 Ute Series II 2004
    The original Holden power steering hoses are specially shaped to suit and are reinforced inside with a coil.
    Sometimes you can be lucky and stop the leak by tightening the hose clamp (if your leak is at a join) but what usually happens is the hose clamp is tightened so much that the clamp distorts out of round and leaks as bad if not worse no matter how much you tighten it. The hoses have just enough length to reach so chopping a bit off and retightening isn't an option.
    I replaced both hoses recently here in OZ and it cost about $30 for one and $20 for the other shorter one (from Holden).
    Can you get your dealer to order the hose for you?
  4. NSTG8R
    NSTG8R Member
    SA
    HSV Maloo R8 + VX Berlina 5.7
    try transmission cooler hose. Should be able to bend it close to the original shape so that it'll fit
