statesman 5l wont start!! ecu maybe a problem??? need help asap!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Disturbed_vegeta, Apr 11, 2007.
  1. Disturbed_vegeta
    Disturbed_vegeta I'd Prefer To ROAR!
    Burpengary
    Vs Statesman, Vr Senator 185I, Vs clubby, R32 GT-R
    i just received a clubby ecu (so i could use the hsv chip) from a friend of my mine for my statesman and i tried to swap em over and it crank but no fire!! then i decided to swap em back but i put the hsv chip in the statos ecu but now it still wont fire!! :cry: please help!!
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    Check that it's actually seated correctly.
    Also did you disconnect the positive terminal first?
  3. Disturbed_vegeta
    Burpengary
    no negative.
  4. Disturbed_vegeta
    Burpengary
    but i disconnected the whole battery
  5. Disturbed_vegeta
    Burpengary
    fixed!!! the clubby chip was stuffed!
  6. shaggerz
    shaggerz New Member
    Victoria Point, Brisbane
    2004 VY2 SV8 A4
    *tosses scarf over shoulder* and thats the end of that chapter...
  7. AirStrike
    91' VN SS
    Ummmmmm did you install the knock sensor?
  8. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    car should still start without a knock sensor ECU goes into limp mode and engine warning light will come on
  9. DannyboyDS
    VS Berlina
    Police cops, simpsons.... NICE!
  10. fuel_within
    fuel_within Chief Executive
    CUSTOM VS
    Body Control module...
  11. kopper69
    kopper69 New Member
    VRII Acclaim
    Mate thats all you say and you say the same things in other posts. And if you read, the problem was solved. I dont think the BCM is involved with the starting or running of the engine in any way.
  12. Disturbed_vegeta
    Burpengary
    well im not sure...all i know is that it wouldnt start with the clubby computer in it..or the chip....
  13. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    you sure it is a VS memcal & not a VR one? this will cause exactly what you have described.
    Rob
  14. Disturbed_vegeta
    Burpengary
    yea its a vr clubby one...so will a vs senator one work..
  15. Karen66
    Karen66 New Member
    Logan Central
    VR Statesman
    karen66
    We have a 1994 VR Statesman. It has a beand new battery and starter motor, but their are days when it will not even turn over. Why would it be doing this ?
