Any one fitted a Statesman map light that goes under the passengers blind to a VN? I have the map light - but before I start cutting - a photo of where it go's would be great - or if it cant be fitted becuase there is no hole for it..... Any info would be cool.:thumbsup:
Ther is'nt any brackets or anything the light just mounts in the lining itself,when me daughter brings home me ute i'll get some pics and measurements if ya like Phillip :wax:
Hmm thanks that'll be great.:thumbsup: I fig it had to be in the correct spot and well cut out else it would fall out. So just didn't want to hack into it (like when I was a youngster) and hope for the best.
How easily could you wire that light up to the spot on the rear of a VP Calais. I bought some thinking they fit (cause i like the push in ones, not the switch) but they don't even fit in the hole. ATM theres no light in there, cause i broke the old ones (well, they were pretty **** when i got the car, pulling them out just helped them fall apart)
Easy as. I used a old spotlight plug and soldered the 2 wires up. Orange to power, wire to door switch and black to earth. Look at my 91 VN V8 - fitted extra lights in this week just gone. I recond if you take the plastic holder out the hole would almost be the correct size.
Figured it would be a simple wire job. I'll see if i can find the light i have, but when i looked, it seemed to have quite a large plastic thing on one side, that made it difficult to fit. I have a Stato roof clock (well, 2 lol) i need wired up, so i guess i'll get it all done at the same time
ok got the measurements,its 145 mm to the front edge of the light from the leading edge of the lining,and 65 mm from the edge of the light to the bracket that holds the sun visor,got some piccies IF I CAN LOAD THE BUGGERS Phillip :wax:
Your a champ mate:bow: - I would have started completly in the wrong spot. Have some rep points on me:thumbsup:
