Static89's HK Ute
Static89
I Am Ironman.
Sherwood QLD
VT Berlina S1
I got a HK kingswood ute given to my by a freind , conditions are i have to do it up, ( he is going to help) needs a Fair bit of work,
its a HK kingswood ute 186 red motor 3 speed column shift Pics will be up shortly
Work needing to be done
Both front guards need rust repair
Drivers side floor
Drivers side panel behind the door has to be cut out and repaired then welding back in
Drivers side rear quarter needs to be cut and replaced.
Tailgate repairs and straightnd
Small amount of straigning on the tray
Passenger side rear wheel arch has dent needs popping out.
Re-assemble
Paint ( white)
Things i need to source are
Dash pad
Bench seat ( possible retrim)
Some Chrome trim
Toruno cover and toruno clips
Things i have considered modifying
eliminate bench seat source buckets
Manual on the floor transmition
V8 conversion
SquishyShoes
or something like that
Somewhere here...
Shoes
oi douche,
good luck with the ute, I'm a big fan of hks and would love to see how this ends up. Do you use oldholden as well as jc?
Static89
I Am Ironman.
Sherwood QLD
VT Berlina S1
i dont use old holden to much, i am on it tho, it will be a good project once im done, im not doing much to it at the moment. im waiting to concrete the yard and put a shed in ebfore i really hook in with it.
SquishyShoes
Somewhere here...
Shoes
Keep us posted then. It could take a while though, it took us a year or two to put our shed (but we had to put up with council restrictions and s**t like that). Good Luck. ;)
Morton
For external use only
33
Fairstar the Funship
I love EVERYTHING about this, except the idea to remove bench seats. There's nothing quite like sliding from side to side while drifting around a corner :p
Static89
I Am Ironman.
Sherwood QLD
VT Berlina S1
lol mort, i have decided to leave the bench in it, and keep the manual on the column and just put a carb 8 in it. and just upgrade the box.
HAZZA-VN
BLACK VY SS :)
bump????
