Steering Knock on VP Commodore
yadav
VP 3.8
G'day all
I have a VP Commodore that steering knocks when turning right hand side full lock
It is basically doing the same as what a front wheel drive car would when the CV's are shagged, ie: the harder right i turn the worse it knocks, or if i turn easy right and avoid u-turns, i can avoid making the steering knock
what could be causing this?
_R_J_K_
Zenki S14
How are your swaybar link pins?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Sounds like it could be the rack end. The bit that comes out of the rack and connects to the tie rod end.
yadav
VP 3.8
cheers, will get under the front and check it out
yadav
VP 3.8
turned out to be a split swaybar link pin bush. threw in all new nolathanes and that fixed it.
