Steering wheel horn
Ulloos
44
bexley
vs excuitive, vs wagon, vs statesman and vr calais
hi guys
iv got a 1996 vs statesman, having problems with horn, the horn works when the alarm goes off, but when i press on the steering wheel the horn dose not work, any ideas would be appreciated.
losh1971
North Tas
VE Series I SS Ute
Sounds like the horn button has worn down.
BlackVXGTS
Melbourne, SE
The alarm uses a separate horn which is located high on the passenger side of the engine bay near the firewall. Sounds like you could have a problem with the clock spring coil. Let me know if you want instructions to remove/replace from the Holden VS Service Manual.
Ulloos
44
bexley
thank you for the information, and that would be great and really appreciated if you could give me instructions.
BlackVXGTS
Melbourne, SE
Here you go:
  • 2.2 SRS System Disabling and Enabling Procedure.pdf
  • 2.3 Horn Bar and Airbag Module Assembly.pdf
  • 2.5 Clock Spring Coil.pdf
losh1971
North Tas
VE Series I SS Ute
Works on my phone
BlackVXGTS
Melbourne, SE
What device are you using to try and read the files? They are standard PDF files.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
I'm wondering if someone has had the airbag assembly / steering wheel off and forgotten to reconnect the horn on reassembly. Sometimes it's just the little things that are wrong when we look for the hardest things going wrong.
