steering wheel issue
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by ashbox, Jan 6, 2009.
  1. ashbox
    ashbox back in black
    The Car
    something black
    I'm having a slight issue with my steering wheel after replacing the audio controls.
    yes for those that will ask did i put it back on properly i did and no the car does not need a wheel alignment
    here is my situation.
    before this, my s/w was relatively straight when the tyres were but now they s/w is 90 deg anti-clockwise to where it was.
    this pic will give you an idea.
    any help/info would be appreciated
  2. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    To my understanding when u put the wheel on, the splines on the shaft havent matched up or u have done the nut up tight enough.
    Therefore ur s/w is going to spin on the shaft.
    I cant think of anything else.
  3. ashbox
    The Car
    something black
    yeah i did think of that but the s/w still turns the tyres. i will double check
  4. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    yeh it sounds like the splines arent matched up.
    can I ask why did you remove the wheel completely? The airbag/horn comes out and your able to jimmy the cables through the plastic covers without removing it.
    I would be getting your wheels straight
    then remove the wheel
    then put the wheel back on straight
    sounds simple but try it, somethings gone funny.
    Another tip, before you remove a steering wheel put a line of liquid paper across the splies and shaft, that way when you go to re-match it up you have a reference. :thumbsup:
  5. PaulSV6
    Castle Hill
    Yeah it would still turn the tyres, its just that it will move over the splines rather than sitting in between them as it should.
  6. ashbox
    The Car
    something black
    i removed the wheel completely so i could paint the spokes.
    i will attack it later on today.
    once the wheels are straight i'll get holden to clear the srs fault.
    i forgot to plug the airbag back in.
