Steering wheel just need grease??
evBenji
VY Commodore
My wheels a bit noisy
the rubbing noise sounds right behind the steering wheel
the shoes on the rack arent leaking, there no leaks under the car, the power steer resevior does have a slow loss rate though
but the noise is just rubbing coming from inside the car
could it be something more
Wombles
Cars cost too much.
Think its where it goes through the firewall. Needs a spray.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Wombles is correct - the noise can be fixed by spraying with WD40 or similar the steering shaft where it passes through the firewall - there is a plastic grommet that dries out. Access is best from under the car. Re the slow loss of PS fluid, try adding some PS stop leak - this works wonders.
evBenji
VY Commodore
cheers guys
with the slow leak ive heard the ps pump has a gasket that can be changed?
also got a noise with the revs, could be the alternator, but could be the ps pump, but sounds like a windmill when I accelorate
evBenji
VY Commodore
cheers guys
well got under the dash, found the cap thing that bolted to frewall via 2 nuts
yep the noise is coming from there, sprayed grease on it, tried to undo the 2 bolts and slide the cap back (to get more grease into it) but guess its not built that way
noise rubbing still exists but hopefully a couple of drives it will seep through
Brett_jjj
Tamworth NSW
vs commodore
Spay it with WD40 from the engine bay side..
grnvs
vs v8 5spd 9c1
I put grease into it with ascrewdriver from the inside from memory and it worked. It was ages ago on my old car but pretty sure thats what i did
grnvs
vs v8 5spd 9c1
Actually i hink it was the on the outside of the firewall. Put the grease in.
BradCalais
Adelaide SA
92 VP SS rep
If u get a can of WD40, all u lave to do is get under the dash (u may need to remove a plastic garnish) the straw attachment is a must use your hand to follow the steering column to the firewall, be sure you get it right at the firewall and not the circular part b4. its the mistake i made... i did this yesterday worked instantly, took a hefty spray tho.
Now my cabin smells of WD40... Bitches love the smell of WD40 hahaha
