hey all, i want to recenter my steering wheel, when the wheels are straight, the steering wheel is sitting at about 11 o'clock, i've had wheel alignment so all is good on that side.. how does the cover come off? does it just clip off from the bottom up? i just didnt want to start prying coz of the airbag.. should just be a nut to remove and resetting the wheel on the spine.. thanks in advance
You really need to look at a manual as there is almost a full page of instructions and warnings on removing the steering wheel - your library should have a copy for you to photocopy. You don't need a science degree but you need to be aware of the correct procedure. Part of a wheel alignment is centreing the steering wheel which apparently didn't happen in your case. Can you take it back to whoever did the alignment and explain your problem?
The people that did the wheel alignment should have straightened it up, as thats part of it. They adjust the rack ends until the wheel is straight
