Wont fit.
The vy steering shaft is bigger. So the vf steering wheel wont fit.
How do l know this? I've tried. Took a vy shaft ( vt -ve are the same shaft size. Dont know about previous models) to the wreckers. I knew they had vf steering wheel sitting on the shelf. They had ve too. So l tried both. The ve fitted. The vf didn't.
What do you need for it to fit? The vf shaft is not compatible with vt - vz shaft.
Another smaller shaft for one. You cant buy one of the shelf, so need to go to an engineer, & have the spline cut down.
Then there is the airbag & the different systems they use.
I dont think they are. Then there is the legality of it. You need to get it approved, engineered a vass report. I'm still looking into it.
If l ever get an answer, l'll report back.
