Wouldn’t it clean all the old pad material off and lay a new layer??
Yep,no warranty from most,Friends Triton Ute got the wobbles under braking after only 40,000K,both front discs warped for whatever reason.Rotors can warp due to sudden cooling. e.g. going through water when they are hot - or even the car wash. I'm pretty sure the warranty won't cover that.
Brake rotors can warp for any number of reasons with over heating and incorrect cool down being just one cause. That’s why we see cool down laps in all.evels of motor racing. I’ve also seen some porche owners rolling their cars back and forth after race is done and they are back in the pits so brake pads done stay over the same part of a hot rotor for too long (they swear it sucks the heat out and warps or cracks them).
So if you are repeatedly hammering your brakes while on a spirited drive, don’t simply pull over without driving calmly for a while to let the rotors actually cool down. Otherwise you are abusing your vehicle and abuse is not covered under warranty.
But for a dealer to categorically state brakes are not covered under warranty is wrong and bullsh!it should be called for such statements.
If you haven’t been doing such boy racer things on the road, then overheating and warping a rotor on a new low mileage car could be due to brake pad drag causing excessive heat build up. Why the pad is draging on a rotor should be investigated as it could be an assemble or manufacturing fault that causes it. If it is a draging brake pad that is the cause of the wobbles when braking, especially on a car wearing original pads and rotors, then it’s definitely something that should be covered under manufacturers warranty or ACL statutory warranty.
