stereo audio steering controls
fordsparta
60
glen waverly
vt acclaim
i own a VT acclaim. i wish to fit stereo audio controls on steering wheel. same as the calais. has anyone attempted this. any feedback is appreciated. thanks
H
harrop.senator
Guest
Yes if you run the standard stereo all the harness from the wheel controls and everything itll work. The ones from supercheap just allow you to do it all with an aftermarket head unit. I think you may still require the wiring with those. Sorry assumed you had everything.
fordsparta
60
glen waverly
vt acclaim
i have the stereo controls and a clock spring from a calais model.
twoshay
41
VT commodore
am curious how this is done also, been trawling through alot of threads looking to gather all the info I need.
Snowshaddow
Melton
VZ SS 5.7 M6
Very possible with the clockspring to match. I've done it a few times and wired directly from clockspring to the headunit. Some models are wired via the BCM but it's easier to bypass it.
110% doable either way.
