Stereo Speaker Harness.
Discussion in 'Car Audio' started by Nut Kracker, Mar 15, 2014.
Thread Status:
Not open for further replies.
  1. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    Help, Tas.......
  2. Filb
    Filb Member
    gold coast
    VY sedan+ wifes VYII wagon.
    Yes it seems that when ever i connect the earth the fuse blows now the head unit fuse is blowing i even put a 20 amp in instead of the 15amp and pop as soon as the battery is connected
  3. Filb
    Filb Member
    gold coast
    your right help taz
  4. Filb
    Filb Member
    gold coast
    at first i didnt disconnect the battery and i thought that was the problem
  5. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
    IF you are absolutely sure you have wired it correctly, the only thing I can think to do, is to test that the H/U is working properly.
    Wire the H/U directly to the car's battery, by passing the factory loom.
    Put the H/U's earth to the earth on the battery and the constant and accessory + wires to the positive side of the battery.
    Make sure no other wires come into contact with each other or the battery.
    If there is something wrong with it, the H/U's fuse should blow.
    If not, either you are doing something wrong, or there's a fault in the factory wiring.
  6. Filb
    Filb Member
    gold coast
    Ive done that earlier and it fired right up but now when i do it it blows the fuse in the h/u i give up stereo 1 filb 0
  7. Filb
    Filb Member
    gold coast
    i put the factory h/u in via the harness it works straight away ???? aghhh fr**8** it
  8. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
    I don't know mate. It's got me tossed.
    It might be best to take it somewhere and let them nut it out.
    Sorry i couldn't be of any more help.
  9. Filb
    Filb Member
    gold coast
    Man thats all good thanx for all the help you had its got me knackered as whats going on with it
    but thanx for trying "taz" might drop by later and say $$#@^%&*()(*&"> and pow it worx who knows
    cheers again kracker
  10. Filb
    Filb Member
    gold coast
    Bugger i screwed up the endless pages of nonsense damn this stereo
  11. Tasmaniak
    S.E. Melbourne
    What head unit are you fitting?
  12. Tasmaniak
    S.E. Melbourne
    Ok... VY plug is what we call an ISO plug (for the techie geeks it's ISO10487). It's divided into 3 sections as you can see. A, B and C. A and B are the same shape and contain 8 pins each. Your power connections can be made in section A, the bottom one. Section B contains your speakers wires and Section C is a 20 pin plug which contains lots of goodies that guys like myself have fun with.... and you need to back off princess cos you dun #### some **** up if you be messin' that.
    In Section A and Section only.... you need to find these wires...
    Accesories - Yellow
    Constant - Orange/Black
    Illumination - Brown/White
    Earth - Black/White
    Antenna - Yellow/Red
    Now, cos I'm a nice guy... I will redo the list but the second colour will be the matching wire from your new headunit. Once you have done this and can confirm that you have only gotten wires from Section A... let us know.
    Accesories - Yellow = Red On Headunit
    Constant - Orange/Black = YellowOn Headunit
    Illumination - Brown/White = Orange (or Pink if present)On Headunit
    Earth - Black/White = Black On Headunit
    Antenna - Yellow/Red = BlueOn Headunit
  13. Filb
    Filb Member
    gold coast
    Thanx Taz got all the wiring correct as from your description followed your VN-VZ wiring guide and double checked before going to far but still blowing the fuse in the head unit now was blowing fuse in fuse box now blowing in the h/u has got me stumped so i guess ill just have to pay an installer to do it i just dont know whats going on with it now
  14. Filb
    Filb Member
    gold coast
  15. Tasmaniak
    S.E. Melbourne
    ok... there is no real other option here but I believe there must be a dead short between the ground and the power input somewhere. Probably in the headunit.
    I'm going to guess it will do the same if you plugged in the antenna before hooking up the ground wire.
  16. Filb
    Filb Member
    gold coast
    It did the bugger
  17. Tasmaniak
    S.E. Melbourne
    internal dead short in the headunit my friend. Contact your seller... now ensue my rant about buying from actual car audio store and australian based retailers.
  18. Filb
    Filb Member
    gold coast
    ok thanx taz i will do that
    In my defence the wife bought the stereo because her car isnt as cool as mine i have a kenwood stereo in mine
    is it something i have done to cause the short ? in the headunit
    it did work the first time i hooked it up to the battery. Just not after i tried to hook it up to the harness now it just blows the fuse in the headunit
  19. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
    When you wired it to the harness without the battery disconnected (if you did), you may have inadvertently touched another wire briefly somewhere without knowing.
    This may have not been enough to blow the fuse, but may have been sufficient to damage the sensitive circuitry in H/U some how.
    This is only a guess, as it may not have happened that way at all.
    The H/U was probably faulty to begin with.
  20. Filb
    Filb Member
    gold coast
    yaeh took it to installer he did everything i had done and he says h/u faulty or damage circuit
Thread Status:
