Stewart1000
work done by ME
- Sep 4, 2005
- 797
- 9
- 0
- Age
- 34
- Location
- vic
- Website
- www.justcommodores.com.au
- VL twin turbo. VN5L. old jeep, **** mondeo.
i have started my project, its an '97 VL SL, i have already sanded the boot lid back and working on the bonnet, i have taken off the two front guards and i am stuck on how to get that grey plastic off of the door, any ideas?
tip: if you are takeing the side guards off, there is all the bolts ontop and two or three under and then there is 2 screws that hold it on that you need to undo from the inside of the car, for the right it is easy but left is harder so ill explain that one. Unscrew the cover onfront of the front left door (inside the car) it covers the ecu, unsrew the plate that holds the bottom of the ecu in and remove that, jiggle the ecu azroudn and it will come out, move it out of the way, behind that you will be able to see a bolt head, undo that but there is another one hidden under that filler crap, so follow your finger down from that bolt hole and locate that bit bulge of crap and just get it off with a screw driver of anything, its a 10mm bolt but the goo makes it ard to get a socket onto it so i used a 13 and just turned it around the bolt and it helped get some of the goo off then scraped some more off and yeah just undo it like usual (its a bit fiddley). same for the other side with the goo but there is no ecu.
also, any ideas how to take the aerial out?
Here asre some photoes i just took, back to work on the car now, thanks
