Burst Knock are turned off at the moment. VFII has no flex fuel sensor and I think injectors are no compatible but they may survive half tank.make sure its not burst knock retard ? if u have the ability to run some ethanol thru it and it still knocks id say its false
its part of the flex sensor output to the ecu so nothing we can change, fuels like ethanol can get affected if the actual fuel heats up (does take a bit tho) and it affects the AFR, some have it for a reason best to use one with it@07GTS being meaning to ask you about the temp offset. How does all that work? Does the ECU use that info or does the sensor change the alcohol Hz when temp is high???
Put $10 e85 and fill tank, drive 50 km for trims to LTFT then another $15, monitor onboard with OBD before dropping her into it.Burst Knock are turned off at the moment. VFII has no flex fuel sensor and I think injectors are no compatible but they may survive half tank.
I will also try octane booster to see if it improves.
