Stock Camshaft, Increased Rocker Ratio
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Skrrt, Jun 9, 2019.
  1. Skrrt
    Skrrt Member
    Australia
    VE Z Series sv6
    Has anyone kept stock cams in their LS1/2/3 but put bigger rockers in?
    My thinking is that this will net some good down-low performance.
  2. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    not worth it for the cost imo since the LS uses 1.7 standard going to 1.8 isn't much, think i gained like 10rkw
  3. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Would probably gain more with a set of heads with improved flow.
  4. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    Did you notice much difference in throttle response and torque?
  5. 07GTS
    Australia
    VEGTS BLOWN E85
    was little seemed smoother prob from the roller tips, from an overall cost v gains just isnt worth it to me as the stock rockers do quite well and i done a cam anyway and then couldnt use the rockers so all that cost is just sitting in my shed now, all i would recomend is to do the trinion upgrade and save for a cam
    vr304 likes this.
