sounds like you might be best puttin it on a trailer to the tuners rather than dive into the ocean and hope you dont get eaten buy a shark..Nah not exactly ive got i t3t4 turbo from ebay so a cheapy but where i am i cant get the car tuned and stuff locally i have to drive an hour to get it tuned so i wasnt sure if i could drive the car down with it setup or if i would have to set it up when i get there? Ive got plans for bigger injectors and fuel pump but would i put them in before i drive down or wait till i get there so the car can be tuned to run the right ratios
It will be far easier to install your stuff beforehand and trailer it there rather than putting stuff in on the side of the road or paying them to do it. If you're taking it to a shop they will be far more favourable to you if you don't waste time doing last minute things (remember that dyno down time waiting for you is lost money to them). The chance for something to break on a new setup like this is also much higher, so you don't want to be stranded roadside if something gives up the ghost on the drive there.
Injectors need to be tuned for, fuel pump not so much but you may find that you run out of fuel while it's on the dyno which hinders its ability to be tuned properly/to potential. If you're driving it untuned on the original injectors it will likely lean out which is less than ideal.
Also worth checking if this shop can do the old Delco ECUs if you're using the stock ECU, tuners that do them seem to be drying up.
