vangara
- Apr 14, 2009
- 24
- 0
- 1
- Location
- Dubai, UAE
- Chevvy Lumina LTZ
Hi All
I am having a strange issue on my 2005 VZ, while driving the car normally, the analog meters(Speedo, RPM, Temp, Fuel) in the instrument cluster go off (fall to the "no-reading" position) and the AIRCON goes off too, but the engine keeps running as usual, even with the cruise control on. The first error that I get is ABS Fault, then I see the hand brake sign continuously on, if I continue to run the car in the same condition I some time see "reduced performance" and some transmission related errors. But if the car is pulled-over with engine running and the gear in Neutral, everything goes back to normal.
I noticed that there is a reading in the trip computer called "ADC BRAKE Reading" and this issue happens every time the reading goes above 2.5. I have to pull-over and change to neutral for a few seconds to bring down the ADC brake reading, then the analog meters start working. We are stumped, unable to trace the issue for the last one month, I have seen similar issues reported in these forums but there are no clear pointers and the gentleman who started the thread dint mention if it was resolved or how it was resolved?
Nothing on tech2.
Did any one of you come across such issue? Any help appreciated.
Nothing on tech2.
