Strange problem? Please help! Need fixed ASAP!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by laver, May 14, 2012.
  1. laver
    laver burn rubber not your soul
    ballarat, victoria
    vy executive
    My vs is being weird, here's the go I need a new gearbox but when the box starts flaring gears and and the just after it she starts misfiring and idling extremely low before it got down to 100rpm could basically count to 2 between each round, and when I accelerate nothing happens doesn't even rev just goes to cut out the only way the car will move is in drive and let it cruise at idle speed, and I just replaced the sensor that controls the idle. Any ideas? Need it fixed ASAP got tradeschool next week and that's in a different town :/
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    checked for error codes?
  3. laver
    ballarat, victoria
    vy executive
    I don't know how to mate :/ how do I do that?
  4. UW1SH
    UW1SH New Member
  5. Jxfwsf
    Aus
    commodore
  6. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    sounds like throttle position sensor but im probly very wrong
    do the error code check and see if anything pops up
  7. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    As above, do a code check.
    If its breaking down under load it may be ignition related.
  8. laver
    ballarat, victoria
    vy executive
    Had a bit of a tinker and turns out your right but also arcing out at the coil packs thanks mate :)
  9. RX25SE
    Fix coil packs first.
  10. ajsvscalais
    ajsvscalais New Member
    Burn-City
    1995 VS Calais
    I nearly had the same problem, i had a vacuum leak and my TPS was on its way out, i think u generally get stuck in a gear when it goes. I fixed my tps, but i still have that problem where the idle is over the place, i think its called 'hunting' and mines dur to a vacuum leak from the o-rings over the injectors, that part is cheap and easy
