strange throttle problem
simoj
adelaide
VTII Berlina
firstly i have a VTII berlina which has been running great ever since i got it. recently i got it serviced and ever since theres been problems. my latest issue has been with the throttle position sensor. the light keeps coming on and then the revs pick up. but then i turn the car on and off and the issues gone. this didnt worry me until i got in my car yesty and turned it on no problem but then i went to rev it ( only a little up to 1500rmp) and it choked and almost stalled. im assuming that there is something wrong with my throttle. any suggestions?
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
DLFHUB666
GIT 'EERRR DONE!!!
39
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
If you can get a hold of a scan tool that does live readings you will be able to see what the TPS is doing an rule it out/in as the problem.
vncruzr
wyndhamvale vic
VY LS1
Mate try change the throttle sensor not that expensive also check for split or broken rocker cover to throttle body hoses!!!! Mate my brother had the same prob.... in his calias and it was the sensor!!!!
simoj
adelaide
VTII Berlina
cheers i had a mechanic plug his computer in and it said it was the throttle position sensor going off. wat reasons could cause it to go off?
DLFHUB666
GIT 'EERRR DONE!!!
39
Nhulunbuy NT
Just buy a new 1 on an be done with it.
simoj
adelaide
VTII Berlina
i bought a new 1 and installed it seems to be running fine. cheers for the tips. i was just wondering wat could make the TPS go off?
smickgmh
ballarat
vx ss
im having problems with my vx ss throttle sensor computer i think ? the car starts then stalls as if theres no fuel ? and the computer in the kick panel is getting hot ?
accentstencil
71
They just wear out with age.
accentstencil
71
As suggested in the second reply to this thread, do a fault (error) code check. There is a link to how to do it.
