Just file new "flats" onto the bolt with a flat file, and then tap a tight fitting "quality brand " open end spanner on it, then remove the plug as normal.. My sump plug was completely rounded off when I got my car. I filed new flats onto the plug and got it out. I then used a bench grinder to grind all new flats around the bolt. It was now a size 16mm. It worked so well that its still there 6 years later. I change my oil and filter every 5000 km or around every 3 months roughly, so it sees a lot of use.
Not long ago I read on here that a couple of guys buy brand new sump plugs and washers for every oil change, just so the sump plug doesnt leak or some crap like that.. Ive used the same old copper sealing washer on mine for 6 years also now, and it never leaks, not even a weep. If these new sump plugs are say, around $10 each, and I did this from when I first got my car, then I would have spent $240 on sump plugs. Pfff.
