Stripped sump plug!
surrealistic
Bendigo, VIC
VZ UTE S V6
I went to change my engine oil for the first time since i had my car, and the sum plug is stripped !
Im not sure what i can do about it.. so any ideas would be much appreciated.
n1tr0us
VR acclaim
youll need to get yourself a helicoil kit.... a helicoil is a thread that screws into a taped thread so the sump plug will fit nicely again... im not sure what size youll need, but i wouldnt stress to much can be fixed quite easly
surrealistic
Bendigo, VIC
VZ UTE S V6
Ok maybe i was not so clear, the bolt is still in and the head has been rounded !
or will this helicoil kit get the bolt out to?
CANYONERO
Likes Cheese...
Country SA
V8 6spd wif MOMO leavaa.
if its the bolt head, just get a new one from a holden dealer or try a wrecker. to get it out? umm thats harder.
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Get yourself a pair of vice grips. They are like a pair of pliers but they lock on to anything that you want to get a good grip on. You should be able to buy a new sump plug from a place like repco or autobarn.
IBLOWN
44
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
I think he means the hex has rounded on the bolt.
Get a hammer and chisel, tap the chisel with the hammer anti clockwise on the head of the bolt, try not to hit it too hard or you might crack the alum cast sump. Bumhole of a job changing a sump in an ecotec. Sump plug threads are fairly fine, so once the bolt is cracked it should screw out by hand.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Hmmm - do you mean the bolt head is fubar or the thread is stripped or both???
Rounded bolt head = whatever spanner you can get it to turn or as a last resort try vice grips
Stripped bolt = helicoil after you get it out
Both = Use whatever you can find to get it out - probably vice grips (as bad as they are)
Reaper
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
Ok mate.. Easiest way is to get a 17 or 18mm socket and hammer it onto the sump. Using a torque wrench or a long handled ratchet, get the bloody thing off and chuck it in the bin..
If that fails, try the chisel thing.. This happened on my girlfriends AU when she tried to get the plug off with an open ended spanner and rounded the thing off like a bitch..
It worked..
protossw
VR 3.8 EXECUTIVE
my god, it seems every thing will happen on a car
good luck
