strut change
smc69
97 VS series2 berlina
how hard is it to change the struts on a vs sedan v6?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Not too hard at all. You will need spring compressors though if yours isn't lowered.
With the car on the ground, crack the top nut on the strut, but don't remove it.
Jack the car up and support it with the suspension hanging.
Remove the wheels.
Undo the stabilizer bar link pins.
Remove the brake line from the bracket on the strut by twisting it until it slides out. (The black plastic holder has two flats on it that slide out through the bracket.)
Undo the two bolts that mount the strut to the stub axle.
Undo the top nut all the way, holding the strut so it doesn't drop out.
Support the assembly in a vice and crack the retaining nut on top of the strut.
Compress the spring until the nut is loose and remove it.
Remove each part of the bush and bearing making sure to keep them in order so you get them back in in the right order.
Remove the spring.
Assembly is the reverse.
While not essential, it is recommended to get a wheel alignment done as you have undone the bolt where the camber is adjusted.
smc69
thanx mate appreciate it
Disturbed_vegeta
I'd Prefer To ROAR!
Burpengary
Www.myspace.com
VR Hsv Senator, VX SS, VZ SS Ute 6L, K9 GSXR1000
i didnt use spring compressors on my senator when i lowered it...(did with my stato) but all that happens is that when u rattle gun the bolt off the top i will knock your hand back...not break it or anything like that,
Chirpstr
A new project attack
34
VR Berlina M5, VP M5
Yeah, but make sure your wearing sunny's and your not smiling lool.
DannyboyDS
Just hand me the pliers.
37
VS Berlina
rofl, omfg.... reminds me of how my friends at a wreckers tried to undo a strut and launch the spring succesfully into a seat so they could buy it, instead it barely missed someones head and ended up through a car window.
Chirpstr
34
hahaha I know what your saying.... just like when I was using one of those home made bush removers doing my bushes and missing my dad's dead by a cm fark that was crazy... not only freaked him out, but me as well. We both needed a strong drink after that one lol.
clazzza commy
Launnie
'95 vr executive wagon
hey my front shockies are stuffed and i rand up pedders and they said they will need 2 replace the whole strut and it will cost me $628 after a wheel allignment,is this right?and if so is the price a good?
any feed back would be awsome thanx
matt
stocky
34
about $250 for 2 new struts, $400 for labour. sounds a bit high, but i dont know what pedders struts are worth
