Strut top nut.Where to buy.?
losh1971
North Tas
VE Series I SS Ute
I have a strut if you can pull nut off the nut off the complete assembly without hurting yourself you can have it.
losh1971
North Tas
VE Series I SS Ute
Tell you what, bring me a 600ml Farmers Union iced coffee, (not the strong one) to my work and I will bring in a complete strut to work and you can take it home and keep the lot. I work on Frederick St. PM me if you want it.
krusing
Melbourne, Bayside
Go to a Nut and Bolt place,
As long as you have a sample of the Nut, they should be able to match it up.
krusing
Melbourne, Bayside
@losh1971, sounds like a good plan/deal to strike ;)
losh1971
North Tas
VE Series I SS Ute
Nuts and Bolts have a huge range but doubtful they could match it.
shane_3800
35
places
vr commo
Nope they can't it's a specialised nut. He has mentioned this already. But you can use a standard nut as the top nut.
krusing
Melbourne, Bayside
Correct, it is a specialised nut, as its pressed and has thread compressions,
But I received a pair of struts, and they had nyloc nuts for the Top nuts.
shane_3800
35
places
vr commo
Only the top nut is a locking nut. The lower nut is a plane nut just thin. I believe this is the one he is after.
krusing
Melbourne, Bayside
But the Op said "Stuffed a strut top nut getting it off " so one would assume he is means the actual TOP Nut.
shane_3800
35
places
vr commo
But the Op said " Stuffed a strut top nut getting it off " so one would assume he is means the actual TOP Nut.
So there's two nuts for the strut. One the locking nut is at the top which holds the strut into the car the other is the strut top nut. Both are the same height but the upper one is a locking nut. The only reason the upper nut is thin is so you can fit the little black caps on which is why some shocks just give you a standard nylock nut for the upper.
