Strut tops
-Junior-
S.W. Sydney
vn auto
There is no camber screw on the vn unlike later models, although i see many other vn's lowered and they dont have as much camber as I do.
You can change the camber on the original style tops. You undo the nuts, drop the whole strut down and turn the top to the next bolt holes. Did this on mine and went from about 3/4 degrees to just over 2 degrees.:yeah:
Just remember that if camber is set higher, then the toe and caster must be adjusted accordingly.
