Stuck On The Foglights!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by M1LMO3, Jan 13, 2012.
  1. M1LMO3
    M1LMO3 Member
    A
    N/A
  2. m1lky
    m1lky New Member
    Auckland
    VY SS
    If you give up its pretty easy to just require them.
    Find the dash light wire. Run this as a feed to the switch via a fuse. Then run the wire off the switch through the firewall to a normally closed relay. Connect the relay via a fuse to the positive battery terminal and the other end to your fog lights. Ground them and voila a legally wired fog light setup.
  3. M1LMO3
    M1LMO3 Member
    A
    N/A
