=Calais v8=
Holden Tech Apprentice
- May 17, 2005
- 544
- 6
- 0
- Age
- 37
- Location
- S/E Melbourne
- VSII 5.0L Calais, 13b ae71
so when the amp its plugged into a headunit using the RCA leads, the power is cut when the headunit is turned off?
if the power cable is run straight from the amp to the battery, and the earth is always connected, that would be a complete circuit which means it would always have power. how does the power get shut off on yours?????
EDIT: i noticed my amp has the + terminal, the GND, but also has a "power control wire". im assuming this is what causes the amp to turn off? do i splice this wire with say... the stock headunit power source? will this work? or will i blow stuff up. thanks for the help
