holdenboy
Custom Car Stereo Systems
- Aug 31, 2008
- 2,330
- 16
- 0
- Age
- 42
- Location
- Nelson Bay NSW
- VR Wagon
If thats the sub you wanted to get because of the above reasons then good on you for buying it, and im sure if the only other sub youve had is a Type R (by the way how much power were you giving it?) than im sure you will be very pleased with the results.
My vote is to go for a sealed box, a smaller volume version will sacrifice that flat response weve talked about.
The type / size of the box plays a GREAT part in the type / volume of bass you will experience, the same can be said for box placement too. Ported in general will give you a higher output (volume), while still being a relatively flat response. The downside to a ported box is the size mainly. Whereas a sealed box (again in general) will give you a tighter sound with better SQ and is usually much smaller.
By the way i reckon a 2cu.ft. sealed enclosure is pretty big for sealed, and i would imagine a ~1.5cu.ft. box would some really similar.
