sub draining battery
somefool
Adelaide, SA
www.facebook.com
1991 VN 'S', 1997 Ford Laser 1.6
as above ^ capacitors dont do much besides add weight to your car. Get a good battery, good earths, good cabling.
Nic92
WA
youtube.com
2005 Mitsubishi Evolution 9
b4 when i was running a 500rms, i had a cap installed and the bat power was fine then wen i took the cap out, it would cut out and all and wasnt enough power, so from my experience they really do help
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
i think he's exaggerating a little bit on frying alts and killing bats, any sub/amp is gonna drain the battery..
since wen? it depends on the set up and how much amps its pulling. half the time guys dont bother with upgrading the main grounding points and/or checking the alternator is up 2 scratch.
sweefu
VY Berlina V6 / R31 Skyline
I love how you kids talk about capacitors.
I'm with you mate. We need more details, i run 2kwrms with no dimming of lights, slight voltage drop if i'm a wanker and turn the boost up.
sweefu
Chances are it would have all been fine on 500wrms if you upgraded the factory earths and alternator charge wire 'big 3 upgrade'. 500wrms isn't much at all mate.
DevilDRake
Braaaap
Skye
www.devildrake.deviantart.com
2006 VZ SS 6L Ute
That's lucky xD. I'm running 800WRMS into 2 ohm and my lights dim like hell. But I'm going to assume the battery is on the way out. I am running a 4 guage kit not 0 guage, but with only have a moderate bit of power in mine it should be enough.
EDIT: And no, I'm not using a capacitor. Don't plan on it either unless I just want to stop the dimming, not for more power.
sweefu
If you want to stop your lights dimming, then upgrade the engine bay wiring. Batt- to chassis, Batt- to engine, Batt+ to alternator charge. go to an auto elec have them make up some decent cables with hydraulic hex crimped ends, i imagine for 4awg or even 0awg it can't cost $50, your problem would be fixed. Ensure your earths are rubbed back to absolute bare metal. Unless your battery really is f*cked.
Nic92
WA
youtube.com
ohh i forgot to mention. it was a class A/B amp and it was
Efficiency (average)
67% @ 4-Ohm
58% @ 2-Ohm
i was running at 2ohm
StoneX
44
Hastings
VE Calais-V 6.0L
It still shouldn't cut out unless your power supply wasn't up to the task and I know for sure that a healthy VY electrical system could run that amp with no issue. Your capacitor was a band-aid to cover up another issue.
