woooo
- Jan 13, 2017
- 503
- 173
- 43
- Location
- Australia
- Multiple
Hello. I am looking to install a small sub in the boot of my VF2 SSV sedan. From reading other threads I believe the SSV has a amp in the boot for the rear parcel shelf speakers? I don't want to pull apart the interior of the car or head unit, I just want to add a small sub to the factory system and the factory rear amp if possible. Just want a bit of more bass as it is quite limited at the moment in comparison to my Mercedes E class factory system with sub which was quite good.
So does anyone know if it is possible to simply connect a sub to the factory amp in the boot of the SSV? Not expecting massive bass just enough to know there is a proper sub there. Maybe a 8" sub.
Was browsing and have found hideaway amp and sub units like this kicker 8"? This looks more like what I am after just wondering would it be able to replace my factory amp and connect all the wires from the factory amp into this? Or can I add this ontop of the factory amp?
Or upon further investigation, could I purchase a higher power amp and replace the factory amp with the aftermarket one (plug and play?) and then connect a sub to that amp? Can I connect all the OEM equipment to an aftermarket amp with ease? I want the car to be stock just want a sub in it.
I have no experience in setting up a sub and amp system in a car, so just wanting some input on my options. I quite like the sub and amp in one as it seems clean and easier install?
