calais_cruzin
Calais_Rattling....
- May 23, 2006
- 1,297
- 10
- 0
- Location
- Gold Coast
- 92 VP Calais 3.8
Hey All,
Just have a problem with my amp or subs that has just happened in the past 4 days
What happens is volume on 22 is fine but put up to 23 n i loose a heap of bass. My subs used to crank to around vol 27/28 b4 they peaked
Ive checked all my grounds n power, thinkin that it was unable to ground out properly once on this volume.
Put multi-meter on it n she reads perfect, 12.4 off, 14.3 on, and only loose's around 0.2v wen pumping
Ive got a JBL 75.4 520w amp running 2x JBL 12inch 250rms subs bridged.
I have no idea y this problem has started, cept that i did overheat the amp bout 2weeks ago on a long drive.
The problem has only started on fri night as i noticed it sounded distorted at a level it should be smooth.
I turned me gain down a bit thinking it may have worked its way up a bit but still no change.
Im stuffed if i can think of wats goin on.
Any help would be great,Thanks :thumbsup:
Also what sends the signal for vol control from H/U to amp.
