ok thanks garfa, I was about to come back on and say that playing with the gains did nothing lol. I had it set to jus under 1.5V (which I thought meant it wasn't amplifying the bass that much, so I changed it to be roughly 2 I think, not exactly sure as there is only a marking for 0.5V and thats it. Also, my Bass EQ level is turned all the wy to the left, and always was, so that wasn't a problem.
I was scared that it might be wiring, bcuz I have spent $170 on wires for it already...the guy at jaycar said I that because I have so much power running through my system, I should run the ground straight back to the negative, I was walking out thinking to myself, did I just get screwed over, and I have since come to realise.. Yes I did get screwed over
. (theres a reply for VrWagz1, I have a perfect ground - the actual negative of the battery lol, which also means the wire going from my negative to chassis wouldn't be a factor either).
Also, I have used 4ga wire, as I asked in here, and I believe it was bezz who said it would be fine for what I was going to be running??
The book for theheaduit says I should run a 2ga wire from the battery to a distribution block, with a 4ga wire - no longer than 1m - to the power of the amp. The only reason I haven't done this is bcuz bezz said I should be fine..(
http://forums.justcommodores.com.au/car-audio/75106-car-audio-wiring.html)
So to clairfy, I have 4ga running from positive on battery to power in amp, and 4ga running from ground on amp to negative of battery.
