Yes of course but what I'm saying it's not possible to not turn the wheel. Stationary is a problem but while car is driving it is possible to control it.
Yes there is mechanical linkage between the steering wheels and the front wheels but that’s not the be all and end all of vehicle control. One must look past the simplicities of the mechanical connection and look at the powerful electric motors and the electronic system that control the steering.
If the fault the EPS system is suffering from means the system is actively fighting the driver, who may be a small young female, it may be much more difficult to turn the steering wheels effectively which means control of the vehicle is completely compromised. Heck, depending on the torque capability of the EPS motor and the fault actually occurring, it may be near impossible to turn the steering wheel.
In any case not all drivers are brawny blokes with Senna type reflexes that may better cope with failure of active control which is why this fault is classed a serious safety related defect requiring a recall… The bad part of it all was that Holden took way too long to acknowledge the seriousness of it while they looked for cheap solution…
And really, none of us can say for certain how the system was engineered or whether the system can not actively fight against the driver… or who will be behind the wheel of a car when such ghosts in the machine raise their heads…
Such is a flawed way of thinking about it unless you’ve had detailed involvement in the EPS system design and test.. I haven't had design or test involvement but i loved control systems theory at uni… Regardless I also don’t trust the simplicities of a mechanical connection that is controlled by powerful motors and more importantly now companies handle costly design screw ups…
And on that note, history shows that bad findings can be buried during the test phase… Such shitfuckery is even done by aircraft companies. In one example of shitfuckery, Boeing decided to ignore (and bury) its own test results that saw an outward opening cargo door fail during ground tests. Why, because it was expensive to fix and wasn’t a mandated test for airworthiness compliance. They lost two or three aeroplanes and with them hundreds of lives…
I simply can’t trust GM/Holden knowing that GM has done its own shitfuckery that cost people their lives; the ignition key saga being just one.
Put pure and simple, it’s a rather dangerous fault and shouldn’t be trivialised by saying people can still control their vehicle. And because of the nature of the fault, some may have already killed and we’d never know it was due to EPS failure…
