Hi VC,
Firstly thanks for your kind words, really appreciate it.
I've decided that I will no longer use Penrite products on Ecotecs as if you look at Lifter problems throughout this esteemed forum the common denominator is .................Penrite.
I've used their product in Alloytecs without issue for many years now but Eco's seem to be a bit of a wild card for their product. I've even had the same confirmation from a long term Sprint Store representative and Sprint are the major retailer of Penrite products here in SA, so that speaks volumes to me and remembering that they make their best GP on Penrite products.
Anyway, I've decided to give Nulon a go in this vehicle and am using their Full Synthetic 15W 50 which should be a good compromise in a 250,000k push rod engine. I'm blown away how both Castrol and Mobil specify such thin oils in these engines.
I've spent most of the day cleaning each internal component and even digging out the crud in all the recesses within the head and block along with going over all the rocker and push rod assemblies thoroughly again so that they are super clean. I'd love to be able to clean out the sump but that's just not viable at this stage.
So in the end, I am of the same opinion as VC, that this issue has mainly come about by previous owner neglect and age. I also feel that this engine probably never had an oil change in the last 5 years with him selling me the car with a supposed blown diff which was in fact the right hand rear brake calliper being ceased and the backing plate of the pad only having about a millimetre of steel left in it before it would've been calliper piston against rotor.
Now think of this next time you're sitting at a red light and see a heap of crap bearing down on you in your mirror..............what are their brakes like ?.......... mmmmmm
