Sunroof issues
jscottnjs
VT Senator 5L
Hi all, it seems that my sunfoor has dropped a couple of mm's at the back. Would this need a seal replaced or much worse. To have a look do i need to drop the roof lining? I have attached a pic
EYY
VS Statesman
No and no. Assume it’s a hollandia 700 from what I can see. Just remove 2 black strips on either side that hides the mechanism. Then you’ll need torx bits to adjust the closed position. Very straight forward. If your unsure I’m sure it wouldn’t cost much to have it adjusted at a sunroof place.
jscottnjs
VT Senator 5L
Thank you very much ill check it out tomorrow, sorry to ask a stupid question are the plastic bits inside the car or outside
jscottnjs
VT Senator 5L
Thank you so much i have adjusted the sunroof and now sits flush, thankyou again. There is a very small gap all the way along the rear of the glass so i may need a new seal on the roof but im more than happy now
