Supercharged 355 problem
FUN304
vs ss
I have a problem with my car at the moment, I'll try and describe it as best as possible.
At about 2300rpm, and always in the same spot, if I'm just driving along and slowly accelerating when it hits that spot its as if it just hits a wall and stops building revs unless I put my foot down harder.
It has a 2500 stall, which was rebuilt and the problem was there before I had it done.
Doesn't seem to do it when cold/just started up.
Any have any ideas of what may be the problem?
Thought it may have been a tuning problem but isn't,
have changed plugs and leads,
even new injectors
Mechanic changed over other things also but still there.
I have the car at home now and going to try and sort it out so any help appreciated.
Pub247
Melbourne S.E.
Ford Fairmont
not tune related your positive? maybe fuel related then be checking your fuel pressure and maybe replace regulater.
Oh another best to do it first new rotor button and dissy cap could defenitly be spark breaking down under load
FUN304
vs ss
Had it go in for another tune at a different place even changed to another ecu and couldn't get rid off it.
I will try the other things you said though thanks.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hey mate are you using a standard engine managment
i had the same problem on my vr 355 stroker with twin throttle bodys i tried changing everything and in the end i forked out on a haltech engine manegment and it smooth out every problem the car ever had it really worth the money i reackon
FUN304
vs ss
I had a kalmaker workshop in, then put in a standard one.
I've been thinking of throwing in a haltech
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
its your car mate but on my car it worked so much better in everyway the car felt so different
Hunter SS
Growing Old Disgracefully
Upper Hunter Valley NSW
2006 VE SS
have you looked at your MAP sensor?
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
I was gonna say possibly TPS.
greenfoam
101
VP Executive R-spec
It has to be running out of fuel at 2300, tune or otherwise
Pub247
Melbourne S.E.
Ford Fairmont
mates ed turbo did that at 2700rpm was dissy cap rotor button as it was the most load just as it came off the stall. Worth changing anyway if it hasnt been done yet'
Like i said in original post it either fuel or that
