F
flow=go
Guest
does anybody know a formula to calculate boost for supercharger applications
are you meaning how much boost to make an approximate power level? or compressor maps?flow=go said:does anybody know a formula to calculate boost for supercharger applications
wouldnt it be easier to go for a predetermined and safe static compression ratio then alter the pulley size of your supercharger?flow=go said:thanks had already found couple of hp calculators but got myself an eaton m62 s/c and i want to calculate the boost I would achieve running s/c at max 14000rpm at 1l/rev n a 5lt engine so I can choose compression ratio for engine
and completely innacurate.juzza said:Pretty sure this isn't what you're after but it's still cool..
http://www.superchargersonline.com/hp_calculator.asp
