supers or lows?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by reggie_c2005, Sep 3, 2007.
  1. reggie_c2005
    reggie_c2005 New Member
    1997 vs 2 clubsport
    k guys is superlows all round illegal in victoria height wise? i have a vp v6 live axle. have been defected b4 for cut springs but wanna drop it again lol. so should i go lows or supers?
  2. MUNTED6
    MUNTED6 Banned
    vn berlina
    super lows should be ok aslong as you can fit a coke can under your car or the lowest point of the car then should be fine
  3. Reaper
    RTFM for the ten millionth time. http://www.vicroads.vic.gov.au/NR/rdonlyres/CC48FC10-4D57-4F04-82E1-3BD72EF88340/0/VSI8.pdf, Items 4 and 5. The coke can theory is simply wrong. I have never seen any official guide that mentions one.
    Reaper
  4. coolvxss
    coolvxss New Member
    canberra
    5sp VN Executive1988, VX SS 6sp
    go ultras. Its still legal on my car. i can still just fit a coke can under my car.
    edit: altho might be different on a vp. not sure
  5. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    Mate you have said this on this forum before. It is not correct never has been and is plain STUPIDITY that anyone actually believes it. Stop freaking saying it.
  6. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    correct dylan, coke cans are approx. 150mm (or is it 130mm?) anyway, its 100mm(leagal limit) which a coke can isnt!
    aZk.
  7. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    pack of ciggies?
  8. Morton
    Morton For external use only
    Fairstar the Funship
    It may be all well and good to fit a coke can under there, but if you've reduced the suspension travel by too much, then it's not technically legal. HOWEVER, nine times out of ten, you will only be tested for the 10cm rule.
    Note, however, that your car must remain legal with passengers, and approx 15kg of luggage for each. I think...
  9. greenfoam
    greenfoam New Member
    VP Executive R-spec
    You can change your rego to a 2 seater anytime you want with vicroads:p easy way to loose 20?kgs and gain some height :p
  10. timmy_tam
    timmy_tam New Member
    VN calais 91
    forget the 100mm rule etc etc
    wait till you lowies go on speed humps
    the one outside the ATM at parkmore, everytime i take that at less than 5 km, it still klunks on my sub frame
    and reversing out of my driveway with a towbar klunks too :(
    going back to lows soon :)
  11. Morton
    Haha, I've only got superlows on the front, and lows on the back... but still, I have to crab-crawl over the road-spikes outside work at a dead-set 45 degree angle to avoid any scrapes along the exhaust :p
    lol @ changing to 2-seater greenfoam
    I cruised around for almost a week with no rear seats (while I was removing my sound deadening), and all I could hear was my diff clunking, and whining, and clunking, and whining, and my petrol sloshing, and BOY did it give me the nannies!
  12. AirStrike
    91' VN SS
    Exhaust must hang realllly low! I know I have an 80lt tank, but with Ultras in the ass and 15's on the tank scrapes well before the exhaust does.
  13. Emackulation
    Emackulation Banned
    SE Queensland
    '92 HSV VP GTS
    Well I had Supers all round in my VN, Never got looked at twice by the police, i cant say it was 100% legal or Illegal. I got Roadworthy for it and it sat pretty good, it was stupidly low. Note: I had no Bodykit and 18" wheels.
  14. 1991_Vn2nV
    Exactly.
    If you're scraping with superlows its your own fault. I have a very bulky kit, ultralow fronts and superlow rears and I only ever have to watch when im parking with the front bar.
    Speed humps etc. are no problem if taken on an angle same with driveways (mine is very steep so i go in on very big angle).
    My VS has stock replacement Pedders suspension and I can easily hit the tow bar reversing out the drive on that if I just reverse straight out, yet I can get my VN out no problems at all as long as I leave on the right angle (never hit leaving the drive yet).
    If your hitting with superlows you simply don't know how to drive a lowered vehicle and you should also be able to tell where your car can or can't go.
  15. Morton
    lol, I hear what you're saying, but for the record - the road spikes outside work, are on TOP of an iron speed hump. If my car is stationary, the spikes physically touch my centre muffler. Hence the 45-degree approach, so I land the muffler on the far side of the speed hump :)
