Supporting V8 engine
Discussion in 'VE Holden Commodore (2006 - 2013)' started by UjisCaprice, Nov 25, 2015.
  1. UjisCaprice
    UjisCaprice New Member
    South Coast NSW
    WM Caprice MY08
    Hi all.
    Went to replace my engine mounts and noticed there is only one engine hook, on the passenger side. Has anyone supported a L98 , if so how?
  2. ari666
  3. UjisCaprice
    South Coast NSW
    WM Caprice MY08
    Yes all attached. In previous cars I've held up the engine with a brace, lift engine up slightly and R & R mounts. Was hoping this car would be the same
  4. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    same way, or lift from underneath
  5. UjisCaprice
    South Coast NSW
    WM Caprice MY08
    What I'm saying though there is no hook on the drivers side of the engine, wondering what others have done
  6. mpower
    mpower Well-Known Member
    last time I changed engine mounts in a car I used a jack under the sump, lol.
  7. EYY
    EYY Well-Known Member
    VS Statesman
    Hook it around the exhaust manifold (around the front/rear tube, whichever is diagonally across from the existing lift point.
  8. UjisCaprice
    South Coast NSW
    WM Caprice MY08
    Thanks EVY, around the manifold worked a treat
  9. Smashfist
    Smashfist Active Member
    SE QLD
    440rwhp Cammed VF Ute
    Works fine as long as you use a piece of wood to spread the load (so the walls of the sump are holding most of the load). Unbolt mounts, lift engine, r/r mounts, let engine down and rebolt. Only need the engine lifted for 10-15mins.
