Suspension noise
stevetortilla
74
tortilla flat N.T 0822
vr 5litre
Hi all
New motor install on vr 5 litre
Replaced t5 gearbox mount and have a bumping noise so changed engine mounts still have noise
Where to next ??
Vin999
SA
VSedanS
Hi all
Where to next ??
more info needed, where is noise coming from ? tailshaft ? diff ? suspension ? engine ? something loose hitting body ?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Is it while driving? Check strut tops.
losh1971
North Tas
VE Series I SS Ute
Sounds like tailshaft bearing. Replace it before it blows or you will need a replacement shaft as well as bearing.
stevetortilla
74
vr 5litre
It sounds like the off side strut
Every thing is tight....how do I check without removal
The power steering seems ok, engine mounts ok
greenacc
Searching for the billion
VE Berlina
How's the gap under the strut top hat? Does it only knock once or continuously?
