Suspension noises..............................
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by skaifey77, Sep 5, 2007.
  1. skaifey77
    skaifey77 New Member
    VE SV6 Sportwagon
    I have this knock sound when braking coming from the front assembly somewhere. Normally goes clunk 2-3 times when I brake, sometimes when I turn but not always.
    I have replaced the rotors and pads, radius rod bushes, replaced the link bars/bushes from strut to stabiliser bars, replaced stabiliser bar bushes. Having got frustrated I went to Ultratune and they said I need to replace the control arm and castor bushes as the wheels are moving about 1 inch when I brake, hence the clunk.:cry:
    So I went ahead and did the work suggested and guess what, still clunking.:bang:
    I can feel the knock through the floor as well as the pedal so figured it must be one of the above, but no luck. Could it be the 4 bolts that mount the crossmember to the chassis?
    Can anybody offer any advice?
    Thanking you in advance.
  2. immortality
    Sth Auck, NZ
    have you had a good look at the ball joint on the lower control arm?
  3. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    If it clunks when turning then it should be the link pin.
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Caster bushes and radius rod bushes are the same thing. Sometimes the K frame bolts do come loose, it won't hurt to run a spanner over them. Play in the rack will also make it clunk.
  5. gobrien002
    gobrien002 New Member
    1995 VR Series II S
    I had a Ford once with a similar problem, turned out to be the shocks clicking, replaced and the noise went away ... good luck
  6. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    me mums vn had the same proble so we replaced every rubber on the front and the only one that was stuffed was the control arm to chasis bush (left side) ..........the clunk/bag was pretty bad lol............however this was in a vn so i would guess it would be the same as a vr/s
  7. skaifey77
    VE SV6 Sportwagon
    I thought I did, but may have missed it. The dude at Pedders said they never go though, have you had to replace them before?
  8. skaifey77
    VE SV6 Sportwagon
    I'm so confused, the guy at Ultratune said the caster bushes were the ball joints on the wheel end of the control arms, not the bushes on the radius rods...
    Is the K - frame the term used for the whole front crossmember?
    I'm starting to think maybe steering rack too, but I have also done the tirods now as well.
  9. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    The radius rod and the caster rod are the same thing. The control arm goes from the K frame to the bottom of the strut. The K frame is the whole front cross member thing, because when you look at it, it is shaped like a K.
  10. skaifey77
    VE SV6 Sportwagon
    Would you happen to know the nut size for the K frame bolts?
    I'm gonna have to go out and buy the right size tube socket.
  11. Infus10n
    Infus10n New Member
    Holden Captiva (Work Demo)
    my bearing plates at the top of the strut are stuffed. When you push down on the front of the car u can hear it / feel it. Also gives feedback through the accelerator pedal and sometimes when u turn. especially going over bumps.
    its not really a clunk sound, its hard to explain.
  12. winton
    winton black+manual+19's=sex
    modbury
    vs SS II 5speed vx gts 19's
    mine is doin exactly the same thing when i push down making a weired as tink clunk noise how do ya fix this
  13. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Put your finger on the top nut of the strut as you push the car down, if you can feel it through the nut then chances are the strut is buggered. The only way to fix it is replace it.
