SV6 cruise control fails
Discussion in 'VE Holden Commodore (2006 - 2013)' started by WreckerJim, Jul 17, 2011.
  1. WreckerJim
    WreckerJim New Member
    Hamilton, New Zealand
    VE SV6
    I recently bought an 09 SV6 (to replace my trusty old 89 VN V6) and have noticed that the cruise control stops working (or won't even turn on). After some trial and error I have found that after 5 or 6 flashes when indicating a left turn the cruise control turns off and can't be restarted without turning off the engine. Right turns are ok and the problem doesn't happen if the stalk is in the high beam position all of which leads me to believe the switch cluster is faulty and I will be checking out the warranty next week.
    Has anyone else had this problem, is it common? Knowing this might put me in a stronger position with the dealer.
  2. WHITESSV
    WHITESSV New Member
    Shepparton
    2006 VE SSV
    sounds like some kind of electrical fault.....i have had the cruise on mine and the abs **** it self before than reset after i turn the engine off..if you can replicate the fault with the dealer they will believe you. just show them lol
  3. WreckerJim
    VE SV6
    Took it in to the dealer today - they confirm my suspicions - faulty indicator/cruise control switch cluster. New one on order from Australia and will be replaced under warranty.
  4. WHITESSV
    WHITESSV New Member
    Shepparton
    2006 VE SSV
    Good to hear :)
  5. too jazzy
    too jazzy New Member
    sydney
    N/A
    Thats good news and even better that you were able to replicate the issue with Holden. Saves you time from going back and forth
  6. WreckerJim
    VE SV6
    Indicator switch has been replaced - all now works as it should AND they replaced the cracked plastic trim on the side of the drivers seat where the height/tilt control is - all under warranty. :spot on:
  7. Shorty33
    Shorty33 New Member
    Fly Creek, N.T.
    VE Omega sedan 3.0 2010
    sounds like Jim had a win ! Well done.
