SV6 Diff LSD?
S
SV6190
Guest
if you were to dump the clutch and ride the brake in a sv6 would it spin easy with 2.8.7 diff gears (T/C Off) ? also does it bog out due to the IRS Setup and being a high performance diff it would only single spin ? I haven’t tried a standstill in it but have given it a couple chirps around corners occasionally. Anyone comment on that?
BLACKVZSV8
300 rwhp
50
VZ SV8 M6
Any car will do a standstill with the help of some oil hehe
naf33n
go
The Shire
Supercharged VU SS
its simpley "high perfromance tags" are single spinners. ones with lsd tags are lsd's.
also you can get a single spinner to spin both wheels on some occasions
EvoVIIIJDM
Got Evo?
www.justcommodores.com.au
Evo VIII JDM
my diff is tagged LSD. you should be able to tell when driving your car.
benzor
yawn :(
37
SV6!
They dont do statics.
BLACKVZSV8
300 rwhp
50
VZ SV8 M6
If I can get a sigma to do a static im sure an SV6 would do it...
benzor
yawn :(
37
SV6!
Sigma has a solid clutch, not a dual mass flyhweel that induces slip. Also doesnt have ABS and EBD
Trust me, Ive tried NUMEROUS times, the ABS / EBD Kicks in and stops it spinning, bogs down, then the clutch starts to slip.
with ABS fuse out, at WSid I can dump it and get it to spin, brake and hold it.
BLACKVZSV8
300 rwhp
50
VZ SV8 M6
So you can do statics then?
gslrallysport
VZ AWD One Tonner
Mine's got that same tag, definately doesn't have an LSD though... none of the AWDs do... :(
