SV6 Diff LSD?
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
Has anyone actually red the tag correctly!
Its to do with the diff oil type! In this case "High Performance" Its got nothing to do weather its a LSD or Non LSD.
sp001in
vyma100
40
QLD
VY ute
on the VIN plate: GU4 is a v6 diff 3.08 a code indicates the diff ratio. V8's normally have GU8.
an LSD's axel code is G80. however if your vin doesn't have this code it may still have an lsd. and the old jack up the rear of the car and spin one wheel and see if the other spins the same way does not apply with a posi track diff, as the torque is not sufficient.
they're are two ways to know if your diff is an lsd. 1, call holden with your VIN number and have them check. 2, find a dirt road, drop a skid. if it digs two holes, it is lsd, if it digs 1 hole, it is not an lsd.
Dz811
Just some p-plater
VZ SV6 M6
checked under mine, tag pretty obviously says LSD, so im safe :)
VzVzVz
Port Melbourne
VZ S ute
Mine says LSD. FILL WITH CORRECT LUBRICANT ONLY. I'm guessing its a LSD, not that it does its job
