Paz87
Hi guys I've got a blown ve sv6 llt engine and I've also got a running Lfx sv6 engine with full loom and ecu which I would like to put in blown Ve my question is the only difference i can see between engines is the exhaust outlet is a single port on the lfx and the llt is a 6 port head I also have all the exhaust system of the lfx motor, will it be a straight swap or am I going to run into issue computer wise will Ecus swap work or too much headache or should I just find a llt engine thanks
