SV6 Noisey on startup!!!
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Co_cker, Jan 27, 2007.
  1. Co_cker
    Co_cker New Member
    VZ SV6
    My SV6 2004 makes what appears to be dry top end on start up ? it will make this noise most of the time, but not when the motor is hot. Any experienceing this, or is GMH using ****ty oil on service??????????? any help appreciated.
  2. burnz
    burnz dah dut dut da dah
    springfield
    VFII SS ute M6
    nothing wrong all good
    oil mobil one super synthetic 5w50
    it drain back over night but being thin it gets up the top pretty quick
    say lessthan 3 second's
  3. Rogues
    Rogues New Member
    Odyssey VE Calais
    Co_cker,
    check your power steering fluid..........if you have a leaking hose you are losing enough to create this noise, believe it or not.:unsure:
    This happened to me and "Yep",....it sounded like the top end had ****e itself...sounded worse when first starting at any point, hot or cold and the noise, although still there dissipated dramatically as it got hot.
    Hope this helps, Cheers Rogues
  4. vy-346
    vy-346 New Member
    Sutherland Shire NSW
    FG XR6T 6A & VH-ZXA
    yeah your right, but its a bloody noisy 3 seconds!
  5. Co_cker
    Co_cker New Member
    VZ SV6
    Thanks Rogues,
    Check the fluid all good, but did have a leaking hose.
    Holden Dealer says they cannot hear anything, F***ing lying b***tards.
  6. Co_cker
    Co_cker New Member
    VZ SV6
    Poor Response
    Having minimal feed back from this forum.
    Has anybody else have this problem????
  7. Da Flyin Dutchy
    Da Flyin Dutchy New Member
    Cessnock NSW
    Triton VN 3.8lt
    best investment and protects for "up to" 80000ks +- is Nulon E30 engine additive. Teflon sticks to all components so doesn't run off overnight. Have used this prod. on my ex-car (hyundai) after 95000 ks on clock engine still purrs. Costs about 30 to 35 bucks now. Have more tips if people want to hear them.
  8. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    My conspiracy theory is that all car companies use the worst oil they can find and promote it as the best.
    My fav. oil is Castrol R 5w30. Gets in everywhere and has less load on oil pump. Gets rid of fuel starving flat spot between 3 to 4 g's creating smoother acceleration and more power.
